- Feb 4, 2009
- 35,862
- 17,407
- 136
Not urgent more like something I can’t figure out.
I have some recessed ceiling lights. The cans take something like up to 65 watt incandescent. They work fine with LED what I can’t figure out is when you have a dimmable light and a dimmer switch/slider like the picture I am imagining top of the slider is 100% power in this case let’s stay with 65 watts. The bottom of the slider is zero percent, middle is 50 percent let’s say 32-ish watts. I now have a 40 watt equivalent dimmable LED that uses less than 8-ish watts why does that bulb dim as I slide the dimmer as in even at 20% on the slider I would think that would mean 65 x .2 or 13 watts which is over my current 8-ish watt LED.
Do dimmers not work by reducing power to the bulb? How do they work? How does a lower watt bulb know it should be at 50%
picture and damn I need to clean this
