Digital Logic Problem Statement
GodLovesPunk
148
I'm an electronics engineering undergraduate student at the University of North Texas. I'm taking a class called Digital Logic and we have a semester project. We use Altera Quartus II software. The problem statement is this:
"Using state machine design, input two BCD numbers from switches (on the Altera DE2 board we use), add the two numbers and display the result on the seven segment display. A reset button restarts the state machine to the beginning. Incorporate a state machine that advances states based on a momentary push-button switch input. Test the inputs for validity and display E for error if a non-valid BCD number is entered."
Now I understand the material well, but we've never had a problem like this. Typically the labs are fairly simple and include in depth guidelines. The instructor and TAs are not able to help us; its driving me crazy! Thought I'd take a shot in the dark and see if anyone is somewhat knowledgeable or an expert in digital logic and VHDL. Thanks guys!
PottedMeat
12,363
475
That doesn't seem too hard. You could scribble a simple solution together on paper.
We need to know how many inputs you have. Inputs: Bits in input 1, input 2, reset, clock. Outputs: 7.
I would do the following:
1. Make a chart of all the possible inputs and outputs. For each pair of inputs, you need to translate that into 7 bits - one for each segment. For example 2 + 3 = 5, so 0b00000010 + 0b00000011 -> Segments a,f,g,c,d ( however thats mapped on the logic array )
2. Draw a state machine representation - I think you just use the output state-> 0,1,2,3,4,5,6,7,8,9,E dependent on the states of the 2 inputs, reset, and clock. Basically a sketch of circles and arrows looping back on one another. Like if you send a clock pulse, but the inputs haven't changed, you loop back to that state. Hmm I don't know what the initial state would be, maybe a blank display?
3. I don't know VHDL, My brother did this sort of thing in his CS class, but it seems like you could do this really easily with a lookup table.
degibson
1,389
I don't remember enough VHDL to be helpful with syntax, but PottedMeat's suggestions are basically right-on as far as how to go about the work.
Just remember: think modular. Break the problem into easily-solved pieces. A BCD to 7-Segment translator, for instance (I fondly remember making one of those myself). Don't forget about the 'E' state. :)
