Digital/HD sound question
JAWS1
77
I have a small set of powered, 735 Boston digital speakers (one sub wolfer, two satellite speakers). My motherboard has built in Realtech HD. Can the two be connected in any way?
Tiamat
14,068
As long as your motherboard has digital out that matches the one on your speakers, you are golden. Most likely, you will have to get a 1/8" mini plug to Coax adapter from radio shack. Alternatively, if your motherboard has optical out and your Boston 735 has optical input, you are all set.
JAWS1
77
Thank you Tiamat,
I did have optical on my last board I used with these speakers (Abit). This board is a MSI K9N6, and it has SPDIF but not optical and for some reason not digital. But I did try a stereo adapter on the mini plug and a few others that didn"t really fit . The stereo adapter radio shack gave me fit, but no sound, after plugging into every socket on my tower. I asked them if they had something that would pick up the HD from the realtek. They looked at me like was missing some marbles and they were close, I don"t know much about sound.
PurdueRy
13,837
4
Originally posted by: JAWS1
Thank you Tiamat,
SPDIF is digital. If they gave you a converter from RCA to 1/8" minijack then you can connect that from the SPDIF port to the speakers. You will have to enable digital audio out in the sound drivers however. You typically will have a control panel for the sound settings specific you the manufacturer of your onboard sound.
JAWS1
77
Thanks PerdueRy I will check that out and let you know. I knew spdif was an acronym for something but should have guessed it was something digital. Actually I should have looked it up huh!
JAWS1
77
Interface, got it and thanks. As soon as I read your reply it dragged itself from my muttled mind or whats left of it. I think I knew that once . I know, easy for me to say. Like in trivia games, I'm the one who always says oh dang I knew that answer...
