FightingChance
I just moved my tower so my 3ft digital coax cable doesn't reach my reciever. Can I use any RCA connector cable, or will I have to spring for a 9ft one?
Originally posted by: jonessoda
Is it RCA or coax?
If it's coax, you can actually custom cut and crimp a cable of whatever length you need. It isn't expensive for the tools or connectors, either.
Is it RCA or coax?
I should have been more specific; it's digital coax, which carries S/PDIF signal and has RCA plug ends. Identical in function to TOSlink (optical)
Originally posted by: stevent76
i have used a standard rca as a digital coax for a long time.
