Digicam STILL out of stock. Need Replacement Fast. Plz help.
Xenon14
I ordered a Kodak DX3600 about a month ago from buy.com they still dont' have it. What camera can I get instead...similar features/price.... ~$250, Digital/Optical Zoom, 2.0-2.3 megapixels? Thanks for your input ahead of time.
RossMAN
Grand Nagus
Feb 24, 2000
79,011
431
First do your own research by going to imaging-resource.com dcresource.com and steves-digicams.com then tell us which 2-3 digicams you're considering and we'll help you narrow it down.
You'll get the best possible price if any of these websites carry the camera you're looking for:
dell.com
staples.com
officemax(.)com
officedepot.com
hsn.com
RossMAN
Grand Nagus
Feb 24, 2000
79,011
431
I just used imaging-resource.com's camera finder and found these digicams.
They're all under $300, with zoom, USB, and are currently manufactured.
trulfe
778
i had the same dilema, i narrowed it down to three options
1)Nikon 775
2)Canon A20
3)Sony P-50
I ended up choosing the Canon A20 by reading the reviews online and can say that i am very satisfied. It has just been discontinued and no BestBuy, goodguys or other store around was carrying it or had any left. I happened to go into a Circuit city in the middle of Nowhere that had 1 last one, so i bought it. I ordered online and the company canceled my order saying they were backordered. check your area,but these are the 3 i narrowed my purchase down to. or check e-gay.
Xenon14
Thanks. How would you rate the following three cameras:
Canon PowerShot A20
FujiFilm FinePix 2600 Zoom
Kodak DX3600
RossMAN
Grand Nagus
Feb 24, 2000
79,011
431
Of those choices I'd get the Fuji Finepix 2600, best bang for your buck. The challenge is try finding a place which has this camera in stock for a good price. Good luck.
The Nikon Coolpix 775 and Canon S110 are also great cameras but slightly over your budget.
