I've been looking for a boot drive for my incipient WinXP system. My criteria has been as follows: at least 160GB of space, EIDE, ATA133, 8MB buffer, 7200rpm, good performance (although it doesn't have to be the absolute hottest thing out there) and low operating noise.
Until today I was thinking that my best choices were between the Samsung Spinpoint 160GB and the high-end Hitachi drives, with the former being quieter and the latter performing a little better. However, both of those assertions on my part seem to have fallen apart after more research ... the latest Samsung drives are apparently louder (made with a cheaper JVC motor?), whereas now I see that the newest EIDE Hitachi drive in the 160GB or larger range is apparently only ATA100.
Note that I don't want to buy a SATA drive this time around, since I've read the horror stories about convincing WinXP to talk to a SATA boot drive on a system with SATA RAID capability, like the MSI K8N Neo Platinum that I'll be using. And sorry, not really thinking of SCSI either ... my hardware budget is running a little tight already, and I've got a max of about $125 to spend on whatever drive I end up with.
I also don't think I want a WD Caviar drive, since I'm trying to make this new PC a little quieter to accomodate some of the music work I do, and I know firsthand that the Caviar drives are far from quiet (trying to listen carefully to music over the WD drive I've got right now is not easy). And I most definitely don't want a Maxtor, not after hearing about the failure rate. And the speed of Seagates just isn't competitive, from what I've read (I do also want at least fairly good performance in addition to quiet operation).
So I feel like I've about run out of options here, and hence would like some advice if possible, whether that advice is to consider other drives that I've overlooked, or advice on which of my "standards" is best/easiest to compromise.
