Difficult networking question
gullyrip1
172
I own some multiunit buildings and was pondering putting up some cameras that would record when they detect movement to a computer that at my residence so that I could review at my convience. Any suggestions of the most efficient manner to put system like this together would be greatly appreciated.
spidey07
65,469
How about getting some cameras and a digital VCR?
JackMDS
29,563
432
From a Network and Computing point of view this is Not a Big deal.
There is a lot of Software that can detect movement store, publish or what ever the camera signal (some is even free) check any shareware site for webcam and you can choose what you like.
The problem is the Cameras.
The inexpensive simple Cams are great, but they are USB. I.e. the cables has to be around 15? max.
There is Wireless Cameras, they go for few hundreds $$$ each, and pending on the envioroment you would need additional APs, Antennae etc., and probably will end spend thousands of $$$ on sensetive Wireless Hardware.
There are cable depending cameras, but that means laying cables from all the peripheral spots to your computer.
What the above means?
You need to get a professional person that would survey your property and evaluate what would be the most cost effective method to cover your specific envioroment.
:sun:
