I currently have an Intel Tualatin Celery 1.3Ghz running with the factory supplied thermal pad. I just got a stick of AS Ceramique and was wondering how much improvement I'll get if I applied it on.
Cool. Thanks for the inputs. It's rather scary when the small fry Tualatin can reach temps of up to 51C. I'm guessing it's an internal diode reading. But even then, it's still scary.
