I've posted this hundred times.
There are 2 differnt high density meanings.
1. the real and correct meaning, the size of the ram chip.
for 256Mbit vs 128Mbit, 256Mbit is the higher density ram.
doesn't matter how the ram is built - any Mbit x 4bank x any
2. the wrong meaning, used by pricewatch vendors in the cheap PC133 256MB dimm age.
Such cheap 256MB dimm is double side, total 16 chips, each chip is 128Mbit made by 8Mbit x 4 bank x 4 instead of the normal 4Mbit x 4 bank x 8.
Because of 8Mbit vs 4Mbit, it's called high density.
There are also 2 different bank meanings.
1. the above bank is the bank interleaving inside or between the ram, from 64Mbit ram, all have 4 bank already, one single dimm using 64Mbit ram chips already can do 4-bank interleaving.
2. about how many banks the chipset supports and how many slots on the motherboard, one slot is 2 bank, single side dimm is 1 bank, double side dimm is 2 bank. This bank is not that bank, you don't need 2 double side dimm to get 4-bank interleaving.
