- Apr 29, 2005
- 165
- 0
- 0
whats the difference between the two, and which one should i get considering the alcu is about 10 dollars cheaper
Originally posted by: mariok2006
imo the copper one is not worth the extra cost and cooling power compared to the alcu, there is probably like a 2C difference at most
It's bolted on to the motherboard - not the case - so when the computer experiences vibration while being moved, the motherboard takes the greatest portion of the force from the HSF unit. If you're permanently settled and never move your computers beyond gently carrying them from one desk to another, I don't think you have much to worry about, but I'm going to be taking my system to and from college, etc., so it is more of a concern to me than it would be to you.Originally posted by: JBT
2x the weight for 1-2 C cooler. I've got a CU but an alcu would be fine for those worried about weight. I'm not worried about weight cause the damn thing is bolted on so whats to worry about?
