difference between ups switched or unswitched outlet?
cs120ban
I just bought a rackmount UPS 1500va from tripplite. In the manual there isn't any explanation about these outlets. which outlet should I plug my server? This tripplite provides a software to monitor the ups and shutdown the server.
.... Help ... i'm a nob admin
Bob Anderson
188
The software should show you a graphic image of the outlets, and tell you if the outlet is battery backup or surge protected only. I suspect that all outlets on a rack unit like yours will be backed up.
-Bob
corkyg
Elite Member | Peripherals
27,370
239
The 2nd page photos might help.
Tripp
I don't have a rackmount, but I have two Tripplite UPS's. There are 4 switched and 2 unswitched plugs. The unswitched are surge protected only - not part of the battery backup system. My manual defines them as Type A and B.
A is battery backup and surge protection. That is where computer, monitor and critical devices go.
B is surge protection only. Plug in printers and othger non-essential devices here.
