Difference between Thunderbirds?
Novasan
Is there a noticible difference between the versions of a 1.2GHz 266FSB Thunderbird? I keep seeing different colors, weeks, AXIA, etc and am confused. If there is a difference can I specify a particular type from a vendor? Is there a range of serial numbers that distinquish what type it is?
Thanks for any help any can give. Have a good holiday weekend.
Dark4ng3l
5,061
well unless you o/c you should not worry about the diferences. If you o/c just get an axia stepping chip and it should o/c real well.
