I'm planning an upgrade, and was wondering there was a performance gap between those two CPUs (enough to justify a $35 (CDN) price difference from where I'm buying from)
AMD ATHLON T-BIRD 1.4GHZ 256K FSB266 OEM
AMD ATHLON XP 1600+ 1.4GHZ 256K FSB266 OEM
I'm planning to use the ECS K7S5A mobo. In case you haven't noticed, the theme of my upgrade is "cheap"
Also, right now I only have a stick of 128mb PC-133 SDRAM. How much of a performance hit will I take with sticking to this ram instead of buying new DDR... and a followup, so is this a good time to purchase DDR ram, and if so where should I get it from?
Thanks for your help.
