Difference between these two NEC/MITSUBISHI monitors???
YBS1
Can anyone tell me exactly what the difference between a NEC/MITSUBISHI FP2141SB-BK 22" SuperBright Diamondtron and a NEC/MITSUBISHI DP2070SB-BK 22" SuperBright Diamondtron is? Going from the specs listed I can find they look to be completely identical. Thanks.
Thanks for the reply, that's the conclusion I came to myself about an hour ago after finding the compare link on the NEC/Misubishi site.
I have this exact same question.
But there has to be something better about the Diamond Pro since it's more expensive.
I thought that as well but I'm starting to think the warehouse just has more in stock that say "NEC" on them than "Mitsubishi" at the moment. 🙂
Well, to update for you wolfman...I just ordered the Mitsubishi branded 2070SB-BK, I guess it should be here in a few days. I'll post back with first impressions.
I have the 2070sb....I was a sucker for the Mitsubishi logo, but, I don't have any regrets, it looks cool on the ol' desktop! And, I don't think you will have any regrets either. The Naviset software that comes with it lets you adjust your monitor settings within windows. My only hope is that it will last longer than the Sony GDM-F500 that it replaced. The Sony POS died after 5 years and Sony didn't have any cheap answers. Sony = never again for me.........
m 🙂
