Difference between System clock and Memory speed
Degenerate
I got a 1.8A @ 2.4 right now. All i did was change the FSB (System clock i believe) from 100 to 133. Now running WCPUIDand it says:
System clock = 133Mhz
Memory = 167Mhz
I thought the FSB IS the ram clock speed? If not, how can i change the memory clock speed, because i have a P4PE and it seems to only allow my to select 3 speeds. Would it do any good though?
The memory bus speed goes up with the fsb speed. You can't adjust the speed of the two buses independently, the only thing you can do is change the fsb/mem bus ratio. hth 🙂
