difference between pentiums
coolcyber
4
hi
can anyone tell me the performance differences between
1) Pentium 4
2) Mobile Pentium 4
3) Pentium M
4) Pentium 4 M
and whatever.
im tooo much confused about them.
n0cmonkey
42,936
1. The regular desktop CPU. Comes in two flavors. Grape, which is rarely good but occassionally surprises you (prescott). And cherry, which is always good (northwood).
2. The mobile version of #1. It's seen in some notebooks.
3. The pentium M is an engineering marvel, and I'm currently an AMD fanboy so admitting that is difficult. If you want x86 and long batter life, this is the processor for you. Seen in notebooks and subnotebooks.
4. I think that's just #2.
Cerb
17,484
33
86
1. Desktop P4. Willamette (socket 423), Northwood (socket 478) and Prescott (socket 478 and 755) cores.
2. They sit in notebooks. They make the keyboard really hot. IIRC, they are the desktop ones, with either lower voltage or constant clock speed changing to keep from using tons of power.
3. Highly efficient mobile chip. A 1.4GHz one is around euqal to a desktop P4 2.2GHz. Up to 2 GHz now. They use under 30 watts under full bore (Prescott 3.6GHz can use near 150w, if some sources are correct). When combined with an integrated 802.11b, it's Centrino. New Centrino likely to use 11g, and probably 11i later on. Expensive, but if you really use a laptop on the go, the only other game in town is Transmeta, and they don't exactly have stellar performance.
4. Yup, #2.
