Difference between PC2100 & PC2700
Fencer128
2,700
Hi,
If all else is equal, and you're running both at the lower frequency (i.e. 133MHz as opposed to 166MHz) - then yes, you can mix them.
However, often there are issues that can arise if the DIMM's do not come from the same manufacturer. Trying this should not damage them though, so give it a go.
Good luck,
Andy
compudog
5,782
The difference between the two is the speed at which they read/write data. You can mix them if they are running at the same (lower) speed as Fencer stated.
