- Nov 21, 2000
- 12,218
- 8
- 81
I was avoiding the delta 38cfm fan because of the reported extreme noise levels. However I recently read that the noise is considerably reduced if you use it with an alpha hs, because on an alpha you use the fan to suck and the air is not blowing through a hs. Can anyone verify/disprove this? Any comments are appreciated, especially if you have both the fop38 and alpha
