You can get it here:
http://www.voodoofiles.com/type.asp
Let me tell you, you are gonna have a hard time getting past the Software test with 0 artifacts. It is very sensitive.
When I say I got my card stable at 266/603 I did this:
1. Ran 3DMark2000 and checked very closely for faint snow in the Helicopter sequence on HIGH settings. Then checked for tiny flashing textures in the Advernture sequence on HIGH settings. You have to look very closely, and if you blink, you'll miss it. But it should be absolutely clean. Another was is to check QuakeIII in a game, and stare at a really complex scene. Look for the tiny bits of black flash.
2. Ran 3DMark2001 and made sure it didn't hang on the transitions.
3. Ran a real demanding QuakeIII demo, like The Reverend's Quaver demo, all settings maxed. Ran it twice, at 1280x1024 and 1024x768. You don't want to lock up here, or see the screen go bonkers with black triangles.
4. Ran Artifact Tester 5.0's DirectX 7 test on HARDCORE settings. Got 0 artifacts.
5. Ran Artifact Tester 5.0's Software test. Got 0 artifacts. You might pass the DirectX test but not get by this one with 0 artifacts. At a 606 memory clock I get maybe 47 artifacts, and at 609 I get 217.
If you really want to be a sadist with your video card, you can try running the Vulpine demo and see if it will complete it OK.
Some guys don't believe I broke 600 on the memory, but the tests I ran speak for itself. I did this on stock cooling and room temp of 21 C. The temp of the card stayed around 53 C. This Asus card I got kick's ass!
