"SCSI" means "Small Computer System Interface" and is the de facto standard for Enterprise storage requirements. FC SCSI is a different interface using fibre optics vs. the traditional SCA 80-pin to a backplane or 68-pin to a ribbon cable, drive connection method.
FC SCSI (these days) always requires the use of an external enclosure with a BACKPLANE. where data access times/throughput is a major concern. I.E. big bucks.
Chances are, if you are thinking about using FC SCSI, you already know what it is, b/c it's way expensive.
IIRC, FC SCSI backplanes have a theoretical bandwith throughput of 2GB/second. That's a lot of data! 😎
FC SCSI is typically used in very large NAS arrays (NAS)
