Originally posted by: mugs
Get the one with the hard drive (expensive).
Originally posted by: YoungGun21
Thats easy! Get the Platinum version for sure!
Platinum version $400
vs:
Core version $300 +64MB memory card $60 (its some outrageous price, may not be $60 but its crazy high for 64mb)
20gb vs 64mb? Wow thats an amazingly hard decision...
BE WARNED-> I got an Xbox360 and it lasted less than 30 days... Now I'm going to try my luck with a Wii.
vs:
Can't base your purchase on one experience. These things happen, just return it or send it in for repair. All of the 360s that my friends and I have are still going strong after 6-8 months.
Unlike the wii and PS3 neither xbox comes with built in wifi. You need to use a wired connection or buy a wifi adapter for it (the MS one goes for $80-90).also do they both connect to wireless networks? I have a laptop on a wireless dsl connection and I was wondering if the xbox would connect to that signal
Originally posted by: uhohs
does microcenter still have the 100rebate on xbox360's?
overstock often has premiums for ~350 too.
get the premium.
Originally posted by: blazerazor
the only beef i have with it is it doesn't come ready for a wireless home network. So if you want to connect to your wireless router, coff up another 100 bones.
RIP OFF! pc wireless cards are dirt cheap, and no where near 100 dollars.
