Difference between DFI Lanparty Sli-D and Slid-DR?
RahulM
124
I ordered the SLI-D to be installed in my system, and upon further reading, it seems like the DR is better of the two. And oddly enough, microbytes.ca has it listed 10 bucks cheaper, I have no idea why.
This is what I found on the site:
http://www.anandtech.com/mb/showdoc.aspx?i=2337&p=2
Can someone explain this to me in plain english? What is Sil3114 and FrontX?
From what I understand, Sil3114 makes it possible to add more hard-drives and do Raid5 without any extra Raid controller, correct? And FrontX seems to put some of the ports from the back to the front. This is just a simple understanding from the limited knowledge that I have, so please help me out. I don't have much time before they assemble the PC, so if I need to make any changes, it must be soon.
Thanks a lot. :)
giz02
89
Thanks a lot. :)
You are correct 3114 adds raid 5, but I don't think it allows for MORE drives (not sure on that one though). The D has a 3132 I think (the same as MSI). Both have the nforce sata controller as well. Frontx is an addon bay expansion that brings sata sound and I think firewire/usb to the front of the PC.
I have the DR-UT which is the same as the DR, except you don't get the lan tote and frontx.
RahulM
124
So in practical terms, the Sli-DR is better than Sli-D, right? Especially for ten bucks cheaper. :p
giz02
89
I'd say do!
Pecking order is
Worst
Citation
SLI UT-D
SLI D
SLI UT DR
SLI DR
Cadillac
Best
:cool:
And you don't lose any features going up the food chain
RahulM
124
Thanks giz.
I'm very confused about the pricing though, it's weird that they'd make the better motherboard cheaper...
RahulM
124
Ok, now I see that EVERY site (newegg, tigerdirect, etc.) has the SLI-D listed at a higher price than the SLI-DR... why is that?
