Difference between confidence and arrogance?
Can you be both, one or the other?
And if you consider yourself confident, does that make you arrogant?
Or if you're arrogant and acknowledge it, does that make you confident?
Originally posted by: loki8481
arrogance is confidence without the skills to back it up.
Not quite. Overconfidence is what you are describing. Arrogance, on the other hand, is when you project your own perceived superiority on others.
..and the insistence that you somehow know what's best for others or society.
