1msHow much of a difference is there really between CAS2 and CAS3 ram?
Does the user know what CAS is? What are they upgrading from?Would the user really be able to tell the difference?
Nope RAM access times are spec'd in ms, CAS stands for Column Access Strobe there is also RAS (Row Access Strobe) the total of the two equal the access speed of the ram ie: 10ms.Originally posted by: sellmen
Isn't it 1 cycle, not 1ms?
Thorin
Hmmmm my bad I knew it was column access strobe but I was sure that it was ms based not cycle. My BadOriginally posted by: etech
FAQ
"CAS => Column Address Strobe
It refers to the number of cycles that need to occur between sending the first part of the address to the memory chip and then sending the second part. It's measured in clock cycles - so CAS3 memory requires 3 cycles delay while CAS 2 requires two. ....
Bear in mind, a clock cycle for a PC100 module is 10 nanoseconds so you probably won't notice a significant performance difference. Most systems will accept either latency part. However, there are some systems that require either CL2 or CL3 parts.
Because I was going based on a seemingly incorrect notion that CAS and RAS were time based measurements not cycle based. (Didn't you read the thread?)How did you come out with 1ms without knowing the access time of the RAM?
Originally posted by: gplracer
The user is a teenager that will be playing counterstrike and other games.
