Yes there is a difference! If you are interested in calibrating your monitor properly and having correctly adjusted gamma levels then check this great site:http://www.photoscientia.co.uk/Gamma.htm
As a basic principle: 1st try to achieve correct gamma calibration (I use 2.0) then after that is set adjust your monitors brightness so it's not too dark yet not too bright. Everything will look much more "balanced" and better IMO.
