Difference between boards
clarnibass
I decided to get a Gigabyte motherboard.
Since I'll record audio, I need the computer as quiet as possible. I'm trying to decide between this motherboard:
http://www.giga-byte.com/MotherBoard/Products/Products_GA-K8NS-939.htm
and this motherboard: http://www.giga-byte.com/MotherBoard/Products/Products_GA-K8NS%20Ultra-939.htm
The first doesn't have a chipset fan which is a great plus, but the question is if I'll miss anything important with it, since the second has more features. I don't need firewire, so that isn't an issue. I need to know if the second is better in any way other than extra stuff like two more SATA connectors, firewire, integrated LAN, etc. Some told me it is also a faster mobo but he wasn't very reliable.
Also I just need to make sure either one of those motherboards will work with this graphics card: http://www.newegg.com/Product/Product.asp?Item=N82E16814121185
I won't be playing any games or work with 3D at all.
Thank you very much.
The Pentium Guy
4,327
I would actually get the GA-K8NXP-SLi, the K8NS has a lot of problems with it (especailly when it comes to memory)
