Awww.... 🙂
AR = Angle Range.
The way the SETI client is setup, depending on the angle range of the WU (ie., how the telescope was tilted when the data in the WU was recorded), certain types of analyses are performed on that WU. So for example, the very highest angle range WUs (eg., AR = >1) have much less analysis performed on them than the mids (eg., AR ~0.2 - 0.5). Same goes theoretically for the very low (eg., AR < 0.1). However, there is a bug in the WIN CLI that makes the very lows take longer to process than normal, despite the fact that they should process almost as quickly as the very highs because not much is being looked at in them.
