The Thoroughbred A and B perform identically at the same speed. The A version did not scale well so AMD modified the core slightly - they added one or two layers (I'm not overly sure of the details of how this is done) and laid out the core a little differently. The result is that the B version can be run significantly faster than the A version.
The only reasons to care which core you get is the overclockability and core temperature. If you read Anand's review of the first Thoroughbred B he explains the changes much better than I can.
Originally posted by: brigden
OK, since I don't give a rummy rat's ass about overclocking I'll be fine with either an A or B T'Bred. Just don't want a Palomino...
