difference between 7600GS, 7600GTS, 7600GT?
nVRuckus
Can someone tell me the differences between these 3 models? 7600GS, 7600GTS, 7600GT? Im looking to buy a card in the $120 range and see newegg has these 3 models and I dont know how big a difference there is between the 3. I know the GT is the best I never heard of a GTS till now and im guessing the gs is the worst of the 3? Someone told me the 7600GS is like the 6800GT. the GTS is $10 more than the GS and the GT is $30 more than the GTS is the GTS the best bang for the buck or should i save up the extra $30 for the GT? or should i even just get the GS?
Only game im playing and plan on playing is cs source, with the occasional HL TFC, or HL2 variation of TFC if it ever comes out. My system is a P4 3.2Ghz, 2GB pc24200 ddr2, dual sata 160GB HDs, pci express slot which is currently holding a x300 which sucks in fps on cs source.
The 7600gs is about double the performance your x300. Heres a cheap one http://www.newegg.com/Product/Product.asp?Item=N82E16814143054
The 7600gts is a 7600gt without hardware sli ability. So if you don't plan on buying 2 to sli in the future this is a good option. It's just as fast as a single 7600gt.
The 7600gt in some cases you get higher clocked cards stock but you pay more than the 7600gts for basicly the same performance. Heres a cheaper one for 134.99 shipped http://consolutiontechnology.com/catalog/product_info.php?products_id=71
Both the 7600gts/gt will triple your performance. The 7600gs will double your performance in a nut shell.
It depend on how much you want to spend I guess. All these cards are great upgrades for you with a x300.
