Difference between 3COM 3C905B-TX and 3C905CX-TXM / 3C905C-TXM ?
Hermann
138
From looking at them, the "C" is a lot smaller, smaller chips and fewer chips. Perform basicly the same, haven't had any problems with them. Not sure the differences between the 2 c's. Have you checked 3-Com's site?
gaidin123
962
I thought the C revision had WOL or that remote boot agent thing while the B doesn't? I have had a B card in use since '97 and it's always worked fine. We use the Cs at work and they are much smaller than my old B but then again, they are 5+ years newer than mine. :)
Gaidin
