Difference between 184 pin DDR and 184 pin DDR2 RAM?
Ike0069
4,276
Dell system.
PROCESSOR, 80546, 2.8, 1M, PENTIUM 4 PRESCOTT DT, 533, E0
DUAL IN-LINE MEMORY MODULE, 256, 400M, 32X64, 8K, 184
This show as having 184 pin DDR2 400 RAM.
On Crucials site, it shows DDR RAM as being compatible. Are they basically the same stick? I thought all DDR2 RAM was 240 pin, so I have no idea about this.
bamacre
21,029
What model dell is this?
There is a HUGE difference bettwen DDR and DDR2 memory, one will not work in the other. If you'll tell me the model, I'll know which you need.
Ike0069
4,276
Dimension 3000.
It's a buddies, but I've never even seen the actual machine. He gave the service code and Dell support says that it is DDR2 400.
Ike0069
4,276
