Difference between 16x(8x8) and 8x(16x8) memory?
zener
497
What is the difference between 16x(8x8) and 8x(16x8) memory? Should I use the same type? Thanks
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
16
The first is a double sided DIMM, where the amount of RAM on each separate chip on the DIMM (density) is less.
The second is a single sided DIMM, where the density is higher. There is no performance difference, but I usually prefer single sided DIMMs.
Lichee
645
ok...lemme further ask:
what is the benefit of getting one of the other? wouldnt single sided get a little more hot since they are more dense? good question btw.
Lichee
AndyHui
16
As far as SDRAM goes, heat is not an issue when running at 133MHz or so. SDRAM simply doesn't produce enough heat, certainly not in comparison with RDRAM or perhaps 400MHz+ DDR SRAM.
I prefer single sided SDRAM because there are certain chipsets out there that have a limited number of RAS lines. Some chipsets like the i815E only have 6 RAS lines, meaning they can support a maximum of 3 double sided DIMMs. However, some motherboard manufacturers implement 4 DIMM slots. Having single sided DIMMs means that you can use all 4 DIMM slots, whereas double sided DIMMs means that you cannot.
Kingofcomputer
4,917
8x8 is 2M x 8bit x 4bank = 64Mbit
16x8 is 4M x 8bit x 4bank = 128Mbit
16x8 is higher density chip than 8x8 (here density means higher memory size per chip).
16 chips of 8x8 make up a double side 128MB DIMM, each side has 8 chips.
if use 16x8 to make 128MB DIMM, only need 8 chips, so only need single side.
you can mix them, but need to make sure your motherboard chipset supports both 8x8 and 16x8 type.
also see this thread
