Diff way to mount a fan? could this work?
PhaZe
2,880
hi, instead of doing it the easy way,
like cutting a hole in the panel and mount a fan right over the cpu , could this work?
I have a 120mm fan, and wondered if i could get some type of glue, thermal good or something, that could glue the top of the fan onto the botton flat part of the power supply. its the same position if it were mounted in the panel, except no holes or fan grills...
What can i use for glue that could hold it up?
and that it could stand some heat or so..
bad idea? or no?
p.s
this puts the fan right over my cpu(small case)
Techru
74
Ne0 AsSaSiN,
Moving hot air around, is just that, moving hot air around :D
The reason to mount it on the side panel, and cutting the hole, is to bring fresh cool air in.
PhaZe
2,880
it does have room..
its a small case
but wide
and i have an exaust fan in the front also...
what could i use to glue the fan (top of fan) onto the power supply
il give it a try
lol.....
