Diference between X800 and X800Pro
NetDevil
148
Is there any difference between those two gpu`s? If yes, what it it ?
And another question, Is HIS X800 worth 30$ difference from Leadtek 6600gt ?
ddogg
1,864
361
well the x800pro performs a little better than the non pro X800....
the X800 is clocked at 400Mhz core and 700Mhz memory while the X800 is 450Mhz and 900Mhz memory(i think!!). well if ur only get it for $30 more it might be worth it..but considering the fact that the X800XL and the 6800GT are about $260 now it would be worthless buying this card. the x800pro is also under $250 now making this a no good buy.
http://www.anandtech.com/video/showdoc.aspx?i=2290&p=7
this link compares the X800 to the 6600GT although the X800 is meant to be compared to the 6800NU
NetDevil
148
Well ddogg i wish the price would be the same in romania. Look at the prices here:
ASUS 6600 GT 200$
HIS Radeon X800 254$
GeCube RX800 XL 384$
Gainward 6800GT 446$
If there are no differences in pipelines or vertex shaders between X800 and x800pro i`ll go with the x800.
PS: I see now that the price difference is bigger. Sorry but i miscalculated it the fist post.
ddogg
1,864
361
ASUS 6600 GT 200$
i would go for the 6600GT anyday based on those prices...
ya there are no differences between the two just performance(x800 is just an underclocked version of the x800pro).
ddogg
1,864
361
well if u dont want to upgrade for atleast 2 years then i would suggest getting a higher performing card than the 6600GT. i suggest u wait for the newer generation from both companies to release and then buy an x800xl or 6800GT when those prices come down below 300. if u cant wait then u might as well go for the x800.
BillyBobJoel71
2,610
since when is a gt 260 bucks? the least i saw it was 350. mine was 400. wow prices fall. its the same concept as the 6800 vs 6800 gt: 12 pies vs 16.
ddogg
1,864
361
check on newegg...there was one on rebate for that price! the AGP GTs have fallen below $300, but the PCI-e are still above 300 around 350.
