T2urtle
Did my clutch cable give out?
So I was riding around and about to park, I backed it in while in 1st and clutch held in, I went to kick it up into N, and it stalled. I didnt think much of it and did what I had to do. Came back and started it up fine, pulled clutch in, it had good tension like nothing was wrong and kicked it down into first and BAM, stalled. I figured maybe I didnt hold the clutch all the way down, since Im a noob still (only 1 month of riding). Did it again and same results. I can shift from N to 1st or 2nd without the clutch being held in now but obviously it stalls out. I tired reving it up and kicking it down into first and it seems like I can get it to move a bit, but I had a LONG way home and I didnt want to try since Im still a noob.
Did my clutch cable give out? Something else wrong? I always thought when your clutch cable goes out you have no tension in the lever. Like in a car people say my pedal hit the floor How easy is this fix? I cant see the routing of the cable due to the fairings being on, it doesnt look all too crazy, 8mm socket on the part that connects to my engine. How often do these go out?
I just cleaned and lube up the chain for the first time, not sure if that helped in making things worst.
2004 sukuki gs500 with 10k miles on it.
