Excellent information on surges and surge protection is at:
http://www.lightningsafety.com/nlsi_lhm/IEEE_Guide.pdf" - "How to protect your house and its contents from lightning: IEEE guide for surge protection of equipment connected to AC power and communication circuits"; published by the IEEE in 2005 (the IEEE is a major organization of electrical and electronic engineers).
And also:
http://www.eeel.nist.gov/817/pubs/spd-anthology/files/Surges happen!.pdf
- "NIST recommended practice guide: Surges Happen!: how to protect the appliances in your home"; published by the US National Institute of Standards and Technology in 2001
The IEEE surge guide is aimed at people with some technical background.
Did you read the manufacturer specifications numbers? Does it claim to protect from any typically destructive surge? If located adjacent to electronics and too far from earth ground, then it does not claim any such protection.
Complete nonsense.
Some even have protected equipment warranties
Then read the warranty's fine print.
My TV died yesterday. Musta been a surge.
Fine print is necessary.
And earth one 'whole house' protector.
Service panel protectors are a real good idea.
But from the NIST guide:
"Q - Will a surge protector installed at the service entrance be sufficient for the whole house?
A - There are two answers to than question: Yes for one-link appliances [electronic equipment], No for two-link appliances [equipment connected to power AND phone or cable or....]. Since most homes today have some kind of two-link appliances, the prudent answer to the question would be NO - but that does not mean that a surge protector installed at the service entrance is useless."
Service panel suppressors do not by themselves prevent high voltages from developing between power and phone/cable wires. The NIST surge guide suggests most equipment damage is from high voltage between power and signal wires.
Service panel protectors are very likely to protect anything connected only to power wires from a very near very strong lightning strike. They may or may not protect equipment with both power and signal connections.
Lightning is typically 20,000 amps. So a minimal 'whole house' protector can connect 50,000 amps to earth.
The author of the NIST surge guide looked at surges on power service wires. He found the maximum surge on a residential power service that has any reasonable probability of occurring is 10,000A per wire. That is based on a 100,000A lightning strike to a utility pole adjacent to a house. Service panel protectors with higher ratings just give long life. Recommendations for ratings are in the IEEE surge guide on page 18.
A protector without that low impedance (ie 'less than 10 foot') connection to earth does not claim that protection.
Nonsense.
As explained in the IEEE surge guide (starting page 30) plug-in protectors do not work primarily by earthing a surge. They work by limiting the voltage from each wire (power and signal) to the ground at the protector. The voltage between the wires going to the protected equipment is safe for the protected equipment.
When using a plug-in protector all interconnected equipment needs to be connected to the same protector. External connections, like coax also must go through the protector.
If using a plug-in protector the DirecTV box and receiver and projector need to be connected to the same protector and the dish coax needs to go through the protector.
Westom believes plug-in protectors to not work. Both the IEEE and NIST surge guides say they are effective.
There are some loose ends when using service panel and plug-in protectors. As frowertr notes a very near strike can directly induce voltages on wires like speaker wires. This isn't likely but can happen. And the IEEE surge guide notes something like an air conditioner compressor/condenser on a concrete pad may be at a very different ground (earth) potential from the building wiring (power wires) during a strong surge event. The branch circuit ground wire can have too high an impedance for surge currents to protect it.
A protector is only as effective as its earth ground.
Airplanes regularly get hit by lightning.
Are they crashing?
Do they drag an earthing chain?
