Diagnosing laptop problem?
mikecdm
49
www.heatware.com
I have this compaq laptop thats a few years old. It's running a P4 2.8ghz, and it always gets the BSOD. Some times it can last an hour, sometimes it shuts off in just a few minutes.
It used to be my dads and he took it once to compusa to get repaired but what they did didnt work. They said that the hdd was the problem and they ended up replacing it. I think a week after he got it back it started having the same problem again. I"d try taking it somewhere to get checked out but it's not worth the price. Most places want like $100 to look at it plus what ever they charge. For that price I can get a cheap laptop that I know is going to work.
Is there any where that I can start, somethings that I can check for to see whats wrong with the thing. I tried swapping out the ram with new one, but that didn't work. It has a P4, obviously it puts out a lot of heat. Could it be that it's overheating? I just feel bad about trashing it or getting rid of it when there might be a possibility of getting it to work.
The model is Compaq Presario R3247US
corkyg
Elite Member | Peripherals
27,370
239
There were some laptops built with standard P4 CPUs - not the mobile variety. They were a bad idea to start with and have always been plagued by high temps. Have you tried placing the unit on a cooling pad?
mikecdm
49
www.heatware.com
No, I haven't tried a cooling pad. I did my best to have it on a cool surface and had it lifted for better airflow. I have though about a cooling pad but didn't want to spend any money if it wasn't sure it was going to work. It's also a bit of a hassle to carry both the computer and a cooling pad. As it is the computer isn't very portable.
I knew the P4 was a bad idea from the get go. I told my dad to buy the centrino but he like the higher numbers of the P4 compared to the centrino.
robisbell
Banned
Oct 27, 2007
3,621
well, also, you may want to check to make sure the CPU heatsink and fan are clean and free of dust, will require some finesse in opening it up.
mikecdm
49
www.heatware.com
It's kind of like a big paper weight right now, so I'm not really to scared on opening her up.
robisbell
Banned
Oct 27, 2007
3,621
well, if you want, I do donate systems off and could use another laptop for the elderly I help.
