I have had an issue with my home built computer for the last year or so. The computer will not turn on unless it has been unplugged from the wall or the hard power switch on the back of the PSU is toggled off for a few seconds then back on.
For example, if you shutdown the computer but then try to use the power button on the front of the case it will not respond. Once you unplug the PC from the wall or toggle the hard power switch in the back of the case for five seconds the computer will fire up just fine. Also, the system will not sleep, if it goes to sleep it just dies and will startup as if the plug was pulled. Does this sound like a power supply or possible motherboard issue? It's a home built rig -- Athlon 64 3000+ (OC'd), 1GB DDR RAM, Antec case and power supply, Epox 9NPA+ Ultra NForce4 Ultra motherboard. The system did run properly at one point for at least a year.
Thanks for any help you can provide.
