Diablo 2 Problems
MDE
13,199
I decided to give Diablo 2 another spin tonight (full legal store-bought copy only used by me) and hit a wall. Whenever I install it and try to patch the game, the in game auto-updater tells me that my connection has been lost, and the standalone installer errors out before it even installs anything. If I try running the original I get an error saying "Unable to load function: FT_thunk (Kernel32.dll). If I install the expansion it won't run at all. I've tried compatability mode, uninstalling and reinstalling with reboots in between, using both my CD-RW and DVD drives and nothing has worked. Any possibility it's my game discs? System specs are in my sig.
EDIT: I'm using all the latest drivers, going to try older video drivers right now...
Nohr
7,302
32
101
www.flickr.com
Perhaps try downloading the patch manually from here and install it yourself.
The FT_thunk error is caused by running the game in compatibility mode according to this.
Are the cds scratched?
MDE
13,199
I tried installing the patch manually and it wouldn't install. They're slightly scratched, so that may be it. I just formatted to fix other weird issues going on so we'll see if this gets fixed in the process.
MDE
13,199
The format fixed it along with many other nagging problems I was having.
