Ok heres my setup: Linksys 4 port router with a Netgear wireless router hooked to it. I want to keep the existing router and use the new wireless router as an access point. Problem is every time I disable DHCP on the netgear it fubars the router. I can not even access the config settings. Everything works fine with DHCP enabled on both routers except I can not print to my networked printer from my wireless notebook
Any suggestions?
I forgot to add. how should the wireless router be connected to the existing router. As is regular port on wired router to "internet" port on wireless router
Drew
Any suggestions?
Drew
