DHCP and IP problem with my nic
kersoz2003
hi
I have a serious problem
I am using adsl with Zoom modem X4
And I connect via usrobotics nic card
But nowadays my ip that the dhcp gives me automatically has changed
And I can't connect to internet.My ip was 10.0....something but now it is 192..0.something
Howver when I manually write my dns and ip,then I do connect.Even though I formatted my pc several times this problem of DHCp ip irregularity continues.
what is more tragic is my second nic in my pc works when I connect my ethernet cable to it
with out any ip problem with DHCP
what will be the problem?
JackMDS
29,545
422
Originally posted by: gunrunnerjohn
Use that NIC, problem solved! :D
Come on John how can you suggest to give up one of theses free after rebate things, it is precious. :Q:brokenheart::D
