DFI UT250 GB no post on restarts in xp home
uptemp0
20
i have a dfi ut250gb and i finally got this rig to work a week ago, however sometimes when i leave the computer on for like 5 hours and i do a restart in windows xp, it would jus be blank, no post or anything but motherboard lights are still on, and fans everything still work i really dont know whats wrong. I would need to press reset button. Why wouldn't it just restart, im scared these symptoms would lead to someting more critical later on. It started doing this after i got this computer to work around 7 days running smoothly. I also went into bios and set all the boot up to be hard drive. THIS ONLY HAPPENS "SOMETIMES" when i restart the computer. any suggestions or help?
p.s do you guys suggest to upgrading to service pack 2?
my mobo is also flashed to the newest bios.
CheesePoofs
3,163
Have you tested the computer to make sure its stable?
If not, run prime95 and memtest to make sure both the CPU and memory are stable. This can be the cause of many problems.
