- Oct 20, 2004
- 347
- 0
- 0
Okay I decided to upgrade my computer. Below are the parts that i've attempted to assemble.
CPU: Athlon XP 2500+ Mobile
HS: Thermalright SI-97
MOBO: Used DFI Ultra Infinity from friend with Bios Savior
MEM: Corsair XMS Pro Series PC3200 512MBx2
VID: MSI Ti-4800 AGP
I reset bios (removed battery and set CMOS pin to 2-3) then set Bios Savior to SELECT. I bootup and at first the LEDs on memory don't light up as usual and I don't receive any bios beeps. Second attempt the LEDs light up but not until like 30 seconds after I bootup, at that time the monitor LED becomes solid (which usually indicates i'd be getting video) and then the "No Video" comes up on my monitor (like I don't have my VGA cable plugged in) and then the light shuts off totally. After several attempts the bios screen showed (still no beeps and delayed LEDs on RAM) but only for 5 seconds and then the monitor LED shut off.
What is going on here?! I'm lost without my PC.
