Originally posted by: Mucker
Originally posted by: motodude
Dude I think this board is a POS, if you go to dfi forums half the posts are memory related problems. Maybe DFI sent out a bunch of bad boards,I don't know, I do know those fvcking fanboys over there are spouting the same crap, saying it's the cpu or memory, yeah right. This may be the most customizable board, but if it takes three days just to get it to boot into windows, what's the point, twenty hours of staring at bios screens just does'nt get me off anymore.:roll:
The Ultra-D boards are just fine the way they are. There is simply no other board that can match the memory options of this one. And for that reason, it can be tricky to set up. You should NOT purchase this board unless you are willing to spend alot of time learning/reading, testing, and setting it up. Alot of people don't mind doing that (me for one). This board is a tweakers board period made to extract the very last ounce of performance out of it, make no mistake about it. If you prefer something less challenging, I'd suggest you buy a Dell (dude) or even safer, an I-Mac. The couple of bios options shouldn't eat up more than 30 seconds of your time.
You are simply misinforming people about the Ultra-D when in reality you are either 1) unaware of the hardware requirements for the board, 2) don't know what you are doing or 3) don't care to put the necessary time into learning how to make it fly. To diss the board and make your childish fanboy claims both here and at DFI-Street is irrational. DFI-Street is one of the best online communities around, solidly staffed with a tremendous amount of available info (if one cares to take the time to learn) If you are frustrated that much, make your life easier and get a Dell dude....or be a Steve Jobs fanboy....
m
