Dfi Sli-dr atx pin
JaceAce32
346
I know the Dfi sli-dr requires a 24 pin connector... the question is...
Is it compatible with a 20 to 24 pin converter?
For example if i wanted to use a Antec TrueBlue 480w power supply...
Thanks
RichUK
10,341
678
the pin converter will be fully compatible with the board as will the power supply the only problem is that it might not supply enough power, the reason being is that the extra 4 pins are drawing power from 4 of the current 20 pins, the extra 4 pins is purley for pcie requireing more power in the future, at the moment it is allright, if you are going to use SLI and have two graphics cards then you might need a more powerfull power supply then you curently have...
what are you amps on your 12v rail
ChineseDemocracyGNR
920
It doesn't require a 24-pin connector, you can use a PSU with a 20-pin connector on it without an adapter. In fact I would not recommend the use of an adapter.
RichUK
10,341
678
so can you just fit the normal 20 pin and have the other 4 pins just bare???
PCLamer
so I was a dumbass and didnt know I needed a 24 pin PSU, so I got an Ultra X-Connect which comes with a 20 pin cable.... but I've heard ppl say that it might work fine... question is:
HOW DO I CONNECT IT? CENTERED? TO THE TOP? TO THE BOTTOM? help my mobo wont boot
RichUK
10,341
678
i think (dont quote me) if you plug it in and have four remaining pins on the motherboard to the right of the 20 pin plug ... dont forget that the power conector only plugs in one way ;)
PCLamer
Well.... I got it working... but its not stable... at all. :(
Thanks for ur help - Im gettin a new PSU now. :(
