DFI NFII ULTRA cpu cooling question
SenateDC
35
the dfi nfII Ultra has No heatsink mounting holes would the cooler max aero lite 7 work.... Or is there a better way to cool the processor i have a AMD 3000 Barton
Thanks
PCboy
847
Originally posted by: SenateDC
...is there a better way to cool the processor
Thanks
the new slk-900a doesn't need mounting holes compared to the slk-900u.. if you have 45 bucks to spare. :) IMO, this heatsink is better than the aero lite 7 without the need for mounting holes ;).
link @ heatsinkfactory.com
SenateDC
35
what about the volcano 10 is that better then the aero lite how do you know if its the 3 clip system or not ?
PCboy
847
from this picture, I think it uses the clip.
PCboy
847
but i want to go with the http://images10.newegg.com/productimage/35-103-137-03.JPG but i am not sure it will fit in the DFI NFII ULTRA i saw a setup where the Aero 7+ got in there but i heard the aero 7 lite has a bigger heatsink. I just really want to use the DFI NFII Ultra board but i just need to find a good heat sink from newegg for a good price. UNDER 40 dollars
it'll work.. here ya go.
PCboy
847
Mounting Clip
Coolermaster changed the clip of the aero lite, their previous mounting clip interfered with the first memory bank module. Their previous mounting system was great, it went on and off very easily without having to use a lot of force. This one looks more simple, and will probably be more difficult to install, more on this later.
Final Words
I was a bit annoyed with the mounting clip, at one point I was afraid to damage my core, so be careful when you put it in your system.
it seems that it'll fit, but you have to be careful.
AngryGames
171
Senate:
this is a reply from the lab in Taiwan:
Travis,
We do have this cooling fan in our lab. It worked perfectly fine with NFII. (Aero7+)
If you have any other questions, please feel free to ask either in this thread, or in a PM!
Travis
