Originally posted by: slash196
When I plug in 1 gig (2X512) in the recommended slots, it boots fine, but when I stick the other stick in either of the remaining slots, it just gives me long beeps, and the diagnostic LEDs indicate what I believe to be a RAM problem. Is this fixable, or just a design flaw? I'm running the latest official BIOS.
I'm sure that if you look in your manual, in the RAM section, you will see that you cannot run 3 stick of RAM. It is either 1, 2 or 4. It is clearly written in my gigabyte motherboard manual.
As for why it run with one but not 3, well, 1 stick run single channel. 2 dual channel. Since the mode is activated by the number of modual you have, the if it sees at least 2, it activate dual channel automatically. adding annother one will not put it back to single, but rather create an error as it dont have the required number of module to run dual channel.
Is it fixable. Well, if there was an option to disable dual channel in BIOS, then maybe it could, but the memory controller, being in the CPU, make it rather impossible, unless the memory controller as such option to be configured.
