DFI NF4 Infinity Help...Temperature prob
hbui
88
So i just got my opteron 146 @ 2700Ghz...everything seems normal except my temp flunctuate alot on this mobo. Anyone know if this is normal for this mobo or I should update bios. Bios temp report CPU at 20Celcius. This seems so very low to me as I have this running at 2.7. In Speedfan, it report from 11 Cel to 22 Celcius. Thsi doesn't seem right...
p.s. I should mention that I just got the chip from monarch with a new stepping, CAB1E 0614
cubeless
4,295
i'll answer next week when mine gets in... i ordered the same setup... what volts and cooling u using on the chip?
hbui
88
I'm running mine at 2.7 default voltage. CPUZ shows it at 1.36. This is with a typhoon but i still don't believe my temp is around 20Cel. that's way too off. The only program that will consistently give me a balance reading is Ntune. Everything else gives numbers that flunctuate like crazy. Speedfan, etc. I just read around the forum that this is a known problem for infinity NF4. They still haven't fixed it yet...let me know how yours turn out..
