I use a system of DFI SLI-DR mobo, AMD 3800+ venice, ocz pc4000 vx gold and leadtek 6800GT sli ready gfx card.
My screen is a viewsonic vp201b.
My problem is when i use dvi cable for my monitor and run in solutions higher than 1280x1024 i get wierd dots in som colors. Happens in blue areas and red/yellow areas.
I tried with another gfx card and i dont get the problem.
If i use a dvi > vga converter and the vga plug in the screen i dont have any problems in any solutions.
You can se an example of the problem at the picture i am linking to.
My best gues is some driver problemer or problem with using leadtek card and dfi motherboard.
I really hobe some1 has a clue about this its pretty anoying.
Picture of failure
Picture of failure
