DFI Lanparty UT Ultra-D: No analog sound. Help!
voodoojc
I can't get the analog sound to work so I can use headphones. I've tried plugging the front audio connectors from my case to the plug-in card. Also tried it from the back with the jumpers on 5-6 and 9-10. Got the latest drivers from DFI. Nothing works. Any ideas?
It shows up in device manager okay. The SPDIF Out works, but not analog. I chose Digital and Analog in Realtek's Sound Manager thing. Any other ideas?
I have the same board and the same problem. the only 2 settings in the bios for this is auto and disable. it is set to auto.
Any help?
Try adjusting the volume/speaker settings in Controll Pannell>sounds and Anudio devices>advanced... make sure nothing is muted... Probably a longshot, but I bet you'll feel dumb if thats whats wrong...
